| Oil pump gear pulling tool https://slantsix.org/forum/viewtopic.php?t=65261 |
| Author: | Reed [ Mon Aug 24, 2020 3:31 pm ] |
| Post subject: | Oil pump gear pulling tool |
I recently had occasion to pull the drive gears off of four slant six oil pumps. I needed a tool to do it and found that THIS tie rod end puller worked great after I ground the opening in the jaw a little bit wider. Not much, just a little bit. This is a low priced tool that is perfect for this application. Just in case anyone out there is looking for a cost-effective way to really easily remove the oil pump gear. |
| Author: | Doctor Dodge [ Mon Aug 24, 2020 3:39 pm ] |
| Post subject: | Re: Oil pump gear pulling tool |
Looks a lot like the one I have. DD
| Author: | Reed [ Mon Aug 24, 2020 3:59 pm ] |
Very very similar. Your posts and that picture are what inspired me to search for one. |
