Spade connector for oil pressure switch
https://slantsix.org/forum/viewtopic.php?t=65267
Page 1 of 1
Author:  OGLeanDart270 [ Fri Aug 28, 2020 12:53 pm ]
Post subject:  Spade connector for oil pressure switch
My wiring at the switch end has frayed enough I had to take it off. While trying to get the wire out I mangled the spade a bit. All the similar sized spades from hardware stores I have tried do not fit. Is this a special connector or just a matter of tooling changes on new spades make them not fit?
I'll cobble something together that works but just curious if there is a correct part I can order somewhere.
Brandon
Author:  Reed [ Fri Aug 28, 2020 1:48 pm ]
Post subject:  Re: Spade connector for oil pressure switch
I have always just used a regular female spade terminal that I crimped/stretched to get a snug fit on the sending unit.
Author:  OGLeanDart270 [ Fri Aug 28, 2020 6:58 pm ]
Thanks for the info. I'll just bend and crimp one till I get it to work.
Brandon
Author:  wjajr [ Thu Oct 08, 2020 1:21 pm ]
I think this housing will work on oil pressure switch.
This is the female terminal that fits the above plastic housing:
You can find the brass female terminal at any auto parts store.
Author:  Badvert65 [ Thu Oct 08, 2020 3:11 pm ]
I bought a few of these:
Oil Switch Connector
They fit perfectly.
