| 727 standard depth pan with plug https://slantsix.org/forum/viewtopic.php?t=65272 |
| Author: | sixsignet [ Sat Aug 29, 2020 5:00 pm ] |
| Post subject: | 727 standard depth pan with plug |
Has anyone successfully used a standard-depth aftermarket 727 pan that has a drain plug? I tried one once on a 1974 D-100 and the drain plug assembly touched the filter, so I sent it back. |
| Author: | SlantSixDan [ Sat Aug 29, 2020 5:14 pm ] |
| Post subject: | Re: 727 standard depth pan with plug |
Poor-quality parts = poor-quality results. Use this pan and this gasket, real nice factory parts, and you'll be all smiles. |
| Author: | sixsignet [ Sat Aug 29, 2020 7:16 pm ] |
Do you know of a good standard capacity pan? |
| Author: | SlantSixDan [ Sat Aug 29, 2020 9:14 pm ] |
That is the standard-capacity factory pan for later models. You could just go ahead and use it, all you'd have to do is add a bit more ATF to bring the level up to Full on the dipstick. No other parts or adapters are needed. Or you could scrounge around and try to find a 1962 or 1963 727 trans pan; those had drain plugsā¦but good luck with the search! |
