Dual Disc Ram Clutches ***Looking for interested parties in a clutch/flywheel package
https://slantsix.org/forum/viewtopic.php?t=65283
Page 1 of 11
Author:  AndyZ [ Wed Sep 02, 2020 5:56 am ]
Post subject:  Dual Disc Ram Clutches ***Looking for interested parties in a clutch/flywheel package
Ram Clutches will be making me a dual clutch with pocketed flywheel for the slant and I am seeking others that may want in on this production run.
Here is a link to what they will be making:
https://ramclutches.com/force-95-dual-disc/
The price will be $950. Possibly less if we get enough buyers.
Author:  Greg Ondayko [ Wed Sep 02, 2020 6:28 am ]
Post subject:  Re: ***Looking for interested parties in a clutch/flywheel package from Ram Clutches
I am in
Can we spec 1x23 or 1.0625x10?
What is the flywheel weight?
Author:  Dan-o [ Wed Sep 02, 2020 7:57 am ]
I'm interested. If this all comes together; I just need to get a T-5! :D
Author:  Greg Ondayko [ Wed Sep 02, 2020 8:30 am ]
Dan, thats the easy part!
We are doing all the hard work for ya! :mrgreen:
Author:  Dan-o [ Wed Sep 02, 2020 9:52 am ]
Riding high on the shoulders of giants!
Author:  Greg Ondayko [ Wed Sep 02, 2020 10:23 am ]
If you say so brotha'
Author:  Joshie225 [ Wed Sep 02, 2020 11:16 am ]
I'll take one with an aluminum flywheel and organic discs with a 1"-23 spline. If that's troublesome then a steel flywheel.
Author:  Rick Covalt [ Wed Sep 02, 2020 2:14 pm ]
Will talk to Ryan and see if he is interested.
Author:  Rob Simmons [ Wed Sep 02, 2020 3:07 pm ]
I may be a player in this. Gotta have options for my estate sale.
Author:  slantzilla [ Wed Sep 02, 2020 10:05 pm ]
This for the 122 tooth flywheel?
Author:  Dart270 [ Thu Sep 03, 2020 9:02 am ]
Yes, assuming this is stock slant 122 tooth fly, then I am in for one set for sure, and perhaps two. I will go aluminum, but maybe steel for the 2nd one.
I would need the disc(s) to have the Ford T5 spline (1 1/6" X 10). If I get two, I may request the T56 6 spd spline for a 2nd one.
I saw your post about weights. Those are fairly heavy, but I guess you are able to support much more HP. My alum fly and McLeod B&B setup is 30 lbs all in, and under 40 lbs for a stock cast iron (20 lb) fly.
Thanks!!
Author:  Greg Ondayko [ Thu Sep 03, 2020 9:25 am ]
Dennis, I believe so..
http://www.slantsix.org/forum/viewtopic.php?f=7&t=65281
But I will let Andy Z be the definitive Source of correct Info.
Author:  slantzilla [ Thu Sep 03, 2020 10:53 am ]
Thanks Greg.
At this time I will get in as a "maybe".
Author:  AndyZ [ Fri Sep 04, 2020 6:45 am ]
Yes, this is for the 122 tooth flywheel. Likely all will be large hole so Greg can make some $ on this. :D
Author:  slantzilla [ Fri Sep 04, 2020 9:42 am ]
Thank you! :D
Page 1 of 11 All times are UTC-08:00
