| '60 Seneca push-button auto https://slantsix.org/forum/viewtopic.php?t=65287 |
Page 1 of 3 |
| Author: | hyper_pak [ Thu Sep 03, 2020 6:16 pm ] |
| Post subject: | Re: '60 Seneca push-button auto |
Nice project! My Grand Father had a Seneca, more door! |
| Author: | Rob Simmons [ Thu Sep 03, 2020 6:20 pm ] |
Sweeet! |
| Author: | SlantSixDan [ Thu Sep 03, 2020 6:38 pm ] |
Quote: Hello!
Welcome here—sounds like you are not far from my old stompin' grounds; I grew up near Hampden and I-25, and shopped and worked at a large you-pull wrecking yard out off Santa Fe Boulevard.Quote: After thinking it was the original engine we were rebuilding, I discovered that it's a 1962 motor (thanks to Mr. Dutra's book)
Good you've got that book; it's part of Doug's goldmine (the rest of which is throughout this board). The engine ID section was guest-written by some beardy dude named Dan. Quote: Now if I can just find the right dark metallic turquoise paint for the block (a one year color only). Anybody here know what it was called and/or the paint code for it?
Funny you should ask. Read this long thread all the way through—it was started long ago, so some of the older posts' pics no longer display correctly, but keep on reading through to the newer posts toward the end.You'll want to read this post, too, and this one, and there are all kinds of good, highly cost-effective upgrades and improvements to be made to the engine (even beyond those mentioned in the book), transmission, and other components of the car. Definitely ask a lot of questions! |
| Author: | Greg Ondayko [ Thu Sep 03, 2020 6:39 pm ] |
Suggestions and discussions for that colour are here. http://www.slantsix.org/forum/viewtopic.php?f=1&t=22766 Read through all pages of the post. Greg |
| Author: | lloyd3 [ Thu Sep 03, 2020 7:05 pm ] |
SlantSixDan: Thank you (& others!) for the rapid response! Was that Swiegals? I worked part-time for Dick Jr's (on Federal) Radiator shop back in the 80s and took completed units down there all the time. There were several other yards down there as well, all gone now. Denver is rapidly becoming LA, I fear. Also.....is that AMC Blue (EN-66) the answer? |
| Author: | plymouthcranbrook [ Thu Sep 03, 2020 9:36 pm ] |
My Father had a 60 4 door Slant 6 3 speed manual when I was about 17 or so. Found out it would do 98 MPH. Don't remember why he got rid of it but like most of his cars he probably killed it with no maintenance. |
| Author: | SlantSixDan [ Thu Sep 03, 2020 9:51 pm ] |
Quote: SlantSixDan: Thank you (& others!) for the rapid response! Was that Swiegals?
No, Colorado Auto and Parts—Svigels was up the hill. Click the red text to read the links in any post.Quote: Also.....is that AMC Blue (EN-66) the answer?
No. Again, read the entire thread. All the way through. Even on the pages after the first one.
| Author: | Greg Ondayko [ Fri Sep 04, 2020 10:15 am ] |
Quote: No. Again, read the entire thread. All the way through. Even on the pages after the first one. Be nice now. I told him that too. Greg |
| Author: | SlantSixDan [ Fri Sep 04, 2020 11:31 am ] |
Fuel pump rebuild kits come from Then & Now Automotive. Careful where you buy parts; much of what you can still buy for old cars through normal lines of supply (local parts stores, RockAuto, etc) is poor-quality junk. |
| Author: | lloyd3 [ Sat Sep 05, 2020 10:08 am ] |
Parts are a problem even when you think they shouldn't be. NAPA stuff used to be the gold standard; no longer. Since they are competing with all the discount/junk outlets, it seems to be a race to the bottom. It wasn't like that in the 90s, but it clearly is now. |
| Author: | SlantSixDan [ Mon Sep 07, 2020 4:05 pm ] |
Fab! Sticking with the original-colour body paint? |
| Page 1 of 3 | All times are UTC-08:00 |
