| Lifting Bracket https://slantsix.org/forum/viewtopic.php?t=65363 |
| Author: | a100gary [ Tue Sep 22, 2020 8:19 am ] |
| Post subject: | Lifting Bracket |
Does anybody have a lifting bracket for a /6 for sale? Do you guys use a lifting bracket when you pull a slant engine out of your vehicle? Anyone have the dimensions? I like the idea of having the engine balanced as I swing it through the cab of my A100! Thanks.....Gary |
| Author: | MadScientistMatt [ Wed Sep 23, 2020 11:37 am ] |
| Post subject: | Re: Lifting Bracket |
I just used a chain bolted to the two large holes in the cylinder head (which are there specifically for lifting the engine). |
| Author: | Rick Covalt [ Wed Sep 23, 2020 5:46 pm ] |
I have one, but it is loaned out right now. When I get it back in a day or two, I'll make a drawing with measurements for anyone that wants to make one. |
| Author: | a100gary [ Thu Sep 24, 2020 8:45 am ] |
Thanks Rick. BTW my first car was a 1965 Plymouth Valiant with a 225/ and a 727. That was almost 50 years ago. I've come so far..... Gary |
| Author: | Greg Ondayko [ Thu Sep 24, 2020 10:55 am ] |
I made one out of ~1/4" steel plate scraps. welder up... if I can find the picture I will post it. Greg |
| Author: | Greg Ondayko [ Thu Sep 24, 2020 11:01 am ] |
here ya go. 20191013_202810 by Hyperpack, on Flickr 20191013_202832 by Hyperpack, on Flickr 20191013_202840 by Hyperpack, on Flickr 20191013_202823 by Hyperpack, on FlickrGreg |
| Author: | SpaceFrank [ Thu Sep 24, 2020 11:48 am ] |
I use a load leveler like this one. One bracket on each side bolts to those holes on the cylinder head. You have to remove the valve cover so those cheesy angle brackets don't crush its edge, though. |
| Author: | Rick Covalt [ Thu Sep 24, 2020 5:25 pm ] |
Here is a drawing of mine with measurements. Mine had two holes in it. One for the engine only and one for the engine and transmission. Mine came "factory" on the 1980 airport tug I bought. I'll post a good photo for you later. Mine was 3/8" plate which is probably overkill? Attachment:
| Author: | a100gary [ Thu Sep 24, 2020 10:35 pm ] |
That's awesome Rick!! Thanks! I'll be checking my steel stock tomorrow! |
| Author: | a100gary [ Sun Sep 27, 2020 8:34 am ] |
Hey Greg. That's a beefy lifting bracket! I'm thinking you take the transmission out with the engine, and you get some tilt towards the tranny. Is that accurate? Rick's diagram shows a lifting point toward the front attachment bolt to balance the engine more, which is my application. Rick, I am starting to work on the steel I bought and I think I am going to take the valve cover off and make the head attachment holes more centered. On your diagram do you have room to put the chain side towards the valve cover or towards the carb? Thanks again guys. Gary |
| Author: | Rick Covalt [ Sun Sep 27, 2020 2:13 pm ] |
Not sure what your asking? My bracket allows you to lift the engine with the valve cover on. Hope these pictures help. Attachment: IMG_2292.JPG [ 56.22 KiB | Viewed 5670 times ] Attachment: IMG_2294.JPG [ 67.39 KiB | Viewed 5670 times ] |
| Author: | Rob Simmons [ Sun Sep 27, 2020 5:54 pm ] |
Thanks Rick! Hey Big Mike!! Fire up the welder!! |
| Author: | '67 Dart 270 [ Sun Sep 27, 2020 7:42 pm ] |
Rick's bracket is fantastic, but also SpaceFrank's load leveler is what I use, very cheap and works great as well. |
| Author: | a100gary [ Mon Sep 28, 2020 8:57 am ] |
Rick, that is nicely done!! I'd consider having it chromed! |
| Author: | wjajr [ Thu Oct 08, 2020 5:41 am ] |
67Dart 270: Quote: Rick's bracket is fantastic, but also SpaceFrank's load leveler is what I use, very cheap and works great as well.
Same as I use, a little wheel bearing grease on the worm makes things move a lot easier.
