Oil filter relocation
https://slantsix.org/forum/viewtopic.php?t=65444
Page 1 of 2
Author:  MOUSETRAP [ Tue Oct 20, 2020 5:30 am ]
Post subject:  Oil filter relocation
Should I use an adapter and hoses like a transdapt kit
or should I find a
Australian style oil pump ??
Thanks
Author:  Greg Ondayko [ Tue Oct 20, 2020 5:58 am ]
Post subject:  Re: Oil filter relocation
or should I find a
Thanks
whatever you have access to.
They will both accomplish the same thing. but I think the Aussie pumps are difficult to find in Maine.
Author:  volaredon [ Wed Oct 21, 2020 9:59 am ]
I have never seen an Aussie style pump.how is it different from the slant 6 oil pump that I have gotten used to seeing?
Author:  MJF [ Wed Oct 21, 2020 10:08 am ]
Cut oil filter location from regular pump and thread an-fittings to passages. Then you have aussie pump.
Author:  GTS225 [ Wed Oct 21, 2020 2:02 pm ]
Hey, Don!
https://www.google.com/imgres?imgurl=ht ... egUIARCUAg
It was done that way because the Aussies drive on the left side, with left hand drive, and have a steering column running right down where the oil filter would need space.
DOH! Just re-read this, and realized I wrote "left hand drive", when it should have been "right hand drive".
Sorry for the senior moment, folks.
Roger
Author:  Badvert65 [ Wed Oct 21, 2020 5:49 pm ]
Is there any particular reason you want to relocate the oil filter?
Author:  MOUSETRAP [ Wed Oct 21, 2020 6:57 pm ]
Not really a particular reason other then the mess at oil change and figured a remote setup I could run single or duel filter I don’t like the adapter so the Aussie pump had my attention
Author:  SeanDG [ Wed Oct 21, 2020 11:34 pm ]
Hey, Don!
Roger
Good info, Roger. Learned something new today.
Author:  GTS225 [ Thu Oct 22, 2020 4:53 am ]
CORRECTION! RIGHT HAND DRIVE, NOT "LEFT HAND DRIVE"
Roger
Author:  Badvert65 [ Thu Oct 22, 2020 5:10 am ]
It is a little fancier than it needs to be, but this is the setup on my race engine. I am not a big fan of the upside down oil filter either.
Author:  Greg Ondayko [ Thu Oct 22, 2020 6:05 am ]
Yes sir!
Author:  MJF [ Thu Oct 22, 2020 11:27 am ]
Work in progress :D
Author:  MOUSETRAP [ Thu Oct 22, 2020 2:33 pm ]
Thanks for the answers you guys are great
Author:  SeanDG [ Thu Oct 22, 2020 10:55 pm ]
Work in progress :D
Sounds like a fun project!
Author:  Rick Covalt [ Fri Oct 23, 2020 9:05 am ]
I too thought of cutting off the flange but I think threading in another fitting is going to restrict it and may crack the housing. I would probably weld a small piece of 1/2" plate to pump and tap that to a larger size.
Page 1 of 2 All times are UTC-08:00
