It is currently Sun May 03, 2026 11:43 pm
 Post subject: tranny fluid
PostPosted: Fri Aug 15, 2003 9:35 am
SSRN National Champion
the question is i put a 1/2 quart synthetic tranmission fluin in my torque converter when i reinstalled my rebuilt tranmission. if i use non synthetic tranny fluid to finish filling up the tranmission will this be ok? or do i need to find more synthetic fluid.
PostPosted: Fri Aug 15, 2003 10:03 am
Synthetic is compatible with non synthetic, but I would recommend just filling it up with synthetic. Supposedly synthetic ATF will help your mileage a bit, though that's just heresay. I haven't seen the results myself.
PostPosted: Fri Aug 15, 2003 10:04 am
Check the bottle. I've never used synthetic "trans-missile" fluid, but all the other synthetic lubricants say they are compatible with conventional. I'd bet synthetic trans fluid is, too.
"DW"
EDIT: Mr. Jopapa posted as I was posting and he has verified what I had supposed.
If it ain't broke, fix it!
PostPosted: Fri Aug 15, 2003 6:10 pm
The synthetic trans fluid is supposed to be more heat resistant than the regular, just like the synthetic engine oil.
I just changed the ATF out of my 833OD trans and put in 2 qts syn ATF and 1 qt 0-30 syn motor oil. It shifts better now and I feel better with some oil in there than all ATF.
Cecil
PostPosted: Sat Aug 16, 2003 4:00 am
Great minds & psychopaths, eh? :wink:
PostPosted: Sat Aug 16, 2003 9:22 am
I don't know how to take that, Jopapa, so I'm gonna assume it's a compliment...
"DW"
(Demented Wierdo)
PostPosted: Sat Aug 16, 2003 11:58 am
Well I gotta throw the "psychopaths" part in so that it covers people like me :P
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
