Two Barrel Carburetor Installation.
https://slantsix.org/forum/viewtopic.php?t=65536
Page 1 of 1
Author:  Lovato64 [ Fri Nov 06, 2020 12:35 pm ]
Post subject:  Two Barrel Carburetor Installation.
Planning to install a Holley Street Avenger 2300-series two-barrel (PN HLY-0-80350) and use the aussiespeed 2 BARREL SHORT RUNNER MANIFOLD on my 1964 Dodge Dart. As you guys know it has the rod linkage. How do I change the linkage to cable and what parts do I use?
I was thinking I could swap this gas pedal but not sure if it could work.
https://www.ebay.com/itm/Street-Hot-Rod ... 4902.l9144
Author:  halfafish [ Fri Nov 06, 2020 3:58 pm ]
Post subject:  Re: Two Barrel Carburetor Installation.
The easiest and cleanest fix is to find a 64-66 gas pedal and cable from a V-8 car. It bolts right up to the holes from the slant pedal. If you can't find one of those, a pedal and cable from a 67 and up will work but you have to drill the firewall for the different mounting bolts. It's not hard, but the later pedal hinges from the top while the early one hinges from the bottom.
