It is currently Mon Nov 16, 2026 11:00 am
PostPosted: Thu Aug 14, 2003 12:41 pm
Okay after hours of old post reading and talking to my machinist the S B Ford valves seem to be the best choice the glitch is he doesn't think that valves should be cut more than .050-.060 these will be stainless valves dose that make a difference? and have any of you had problems from removing too much of the hardened tip? need opinions thanks Bruce J.
78b4ramSnortbed/6
 Post subject: caps
PostPosted: Thu Aug 14, 2003 12:51 pm
I'm no expert; but, once you cut it down, can't you just put hardened lash caps on the valve? Wouldn't this do the same thing as the hardened end on the valve stem?
My truck is a Frankenstein creation
Built from the dead carcasses of others
And brought BACK TO LIFE!
PostPosted: Thu Aug 14, 2003 7:51 pm
SBF valves should not need the stems cut. They are the right length to start with. SB Chevy valves are .100" long though. :shock:
