shortening valves,pros/cons
https://slantsix.org/forum/viewtopic.php?t=6556
Author:  Bruce Johnson [ Thu Aug 14, 2003 12:41 pm ]
Post subject:  shortening valves,pros/cons
Okay after hours of old post reading and talking to my machinist the S B Ford valves seem to be the best choice the glitch is he doesn't think that valves should be cut more than .050-.060 these will be stainless valves dose that make a difference? and have any of you had problems from removing too much of the hardened tip? need opinions thanks Bruce J.
Author:  mnecaise [ Thu Aug 14, 2003 12:51 pm ]
Post subject:  caps
I'm no expert; but, once you cut it down, can't you just put hardened lash caps on the valve? Wouldn't this do the same thing as the hardened end on the valve stem?
Author:  slantzilla [ Thu Aug 14, 2003 7:51 pm ]
SBF valves should not need the stems cut. They are the right length to start with. SB Chevy valves are .100" long though. :shock:
