| Fuel cell https://slantsix.org/forum/viewtopic.php?t=65584 |
| Author: | MOUSETRAP [ Sat Nov 21, 2020 4:16 pm ] |
| Post subject: | Fuel cell |
Instead of 1963 tank I’d run fuel cell under floor pan any ideas ? Pros con street strip 12 gallon Race tech issues ? |
| Author: | slantzilla [ Sat Nov 21, 2020 11:12 pm ] |
| Post subject: | Re: Fuel cell |
To be legal in Tech it will have to have a sheet metal cover around it. Also, you may find it hangs down a lot lower than a standard tank. Other than that, I can't think of any reason you can't do it. |
| Author: | Greg Ondayko [ Mon Nov 23, 2020 8:16 am ] |
I have a 5 Gal Fuel Cell in the back. I Welded in some metal to cover the sump below the spare tire / trunk well. It will need a ground wire from the cell onto the chassis itself. I will also need a Vent that goes through the floor to the outside atmosphere. Greg |
