It is currently Mon Nov 09, 2026 6:20 am
PostPosted: Wed Nov 18, 2020 1:19 pm
Hi All, I posted this as a response in another thread but haven't gotten any replies, so thought I'd try again with a new post. Any help you might be able to provide is appreciated.
I'm in contact with Randy Pettey (thanks Dan!) about making me a replacement radiator for my 63 Valiant, and I need to provide him with the dimensions of the original which I no longer have. I did a search and found the followien discussing a 63 Dart:
the dimensions for the radiator are 17" across, 21.5" tall, the mounting flange holes are 21.5" CL to CL. The top tank is 4" wide while the radiator itself is 1.5" wide.
The upper hose connects on the right side (passenger side) and the lower is also on the right side (passenger side). The lower pipe comes out and up to the passenger side. The bottom pipe is about 1.5" from the right side of the radiator (passenger side).
The transmission lines are on the bottom and are 10" apart.
Just want to verify this is correct before I relay it to Randy and have him start the fabrication process. I need overall dimensions across with and without the brackets, height and width (at the tanks and at the core). Thanks all!
PostPosted: Thu Nov 19, 2020 3:39 pm
I have one that I can Check for you.
It's old and leaky and in the scrap pile. I have already desoldered the steel mounting ears but I can set them back on and take some measurements/ Pics.
It was out of a 64 Dart.
PostPosted: Fri Nov 20, 2020 9:03 am
Thanks so much Greg. I appreciate the effort. I really want to avoid giving him inaccurate dims cause there's no going back once he fabs it up. The location of my original radiator is another subject altogether. Somehow I ended up with an old GM unit. It's probably sitting under a pile of other unidentified parts at my buddy's shop.
PostPosted: Mon Nov 23, 2020 3:32 pm
Here is what I found on the Rad from my 64 Dart:
Image20201123_161020 by Hyperpack, on Flickr
Image20201123_160945 by Hyperpack, on Flickr
Image20201123_161036 by Hyperpack, on Flickr
Image20201123_160921 by Hyperpack, on Flickr
Image20201123_160917 by Hyperpack, on Flickr
Image20201123_160840 by Hyperpack, on Flickr
PostPosted: Sat Nov 28, 2020 12:27 pm
Hey Greg, thanks so much for these pics and dimensions. Really appreciate your willingness to help! I'm going to send you a PM.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 5 guests
