It is currently Sat Nov 21, 2026 5:21 am
PostPosted: Sun Jan 03, 2021 3:57 pm
Car Model: Slant Six M37
I am looking at options here. This is for an engine conversion build and I would like to have the option of Power Steering, and a hydraulic lift pump for a snow plow.
I've found a three belt harmonic damper pulley.
A two groove Water pump pulley would make mounting the snow plow pump location much easier. The Power steering pump all ready needs to move up from where the factory installed it, because the frame is in the way. Hoping that I can move the PS pump from the 5 O'clock position up to about the 3 O'clock position, and then using a double Water pump Pulley, I could put the hydraulic pump for the plow about where I have seen pictures of the AC compressor
I am telling myself an Air Conditioning water pump pulley would do the trick, and most everyone has 2 or 3 of them sitting under the work bench collecting dust.
Has anyone used a V8 water pump pulley to cure their belt drive situation ?
All thoughts an opinions welcome.
