It is currently Fri Nov 13, 2026 12:06 am
 Post subject: 61 to 62 k frame swap
PostPosted: Sun Jan 24, 2021 2:50 pm
Can a 61 valiant/ lancer k frame be swapped with a 62-66 k frame to use more standardized steering box and lower control arms?
Thanks Sages,
PostPosted: Sun Jan 24, 2021 3:06 pm
Yes.
Swap it all.
There is a guy on FABO who changed the K but left his frame mount steering box.
I don't think that was a good idea.
PostPosted: Sun Jan 24, 2021 3:17 pm
Okay. I figured that would be the case.
I would not leave that saginaw? frame mount box if I did this swap.
PostPosted: Sun Jan 24, 2021 3:20 pm
Yep. Bolt in swap and nice to have the later steering box.
PostPosted: Sun Jan 24, 2021 4:51 pm
I think he had a rebuilt box, so wanted to keep it.
I think you will have to change or modify the column.
But it's a LOT better system. As you know just about unchanged till 1976.
