| Offy Install Early A Body https://slantsix.org/forum/viewtopic.php?t=65721 |
| Author: | Tireshredder [ Wed Jan 20, 2021 12:20 am ] |
| Post subject: | Offy Install Early A Body |
I bought an Offy intake with dual Webers about a year ago. I’d like to finally install the thing, but I’m not sure how to go about it because I have the rotating rod linkage for throttle and kickdown. Has anyone installed the ProLine setup with the rod linkage or will I have to change to cables? |
| Author: | Greg Ondayko [ Wed Jan 20, 2021 8:57 am ] |
| Post subject: | Re: Offy Install Early A Body |
I would say to switch to a cable throttle and eliminate the rod. If you wish to keep the stock looking gas pedal It could be used with a cable setup from a 1972-1978ish d series truck. Greg |
| Author: | GregCon [ Wed Jan 20, 2021 3:54 pm ] |
You're really getting into the area of hot rodding that involves making your own stuff, as opposed to kits and pre-made parts. I agree, switch to a cable and that will at least make and easier starting point. |
| Author: | Tireshredder [ Wed Jan 20, 2021 4:19 pm ] |
Picked up the early A v8 pedal assembly at the wrecking yard today. 30 bucks and life got a whole lot easier |
| Author: | Greg Ondayko [ Wed Jan 20, 2021 4:51 pm ] |
The fact that you have access to one of those in a wrecking yard is stupendous! Greg |
| Author: | Joshie225 [ Wed Jan 20, 2021 5:19 pm ] |
Quote: Picked up the early A v8 pedal assembly at the wrecking yard today. 30 bucks and life got a whole lot easier
I lived in Mountain View, CA for 3 years in the mid 1990s. I spent plenty of time in the wrecking yards. I had three A bodies to maintain and improve. |
