It is currently Sun Nov 08, 2026 10:40 am
PostPosted: Tue Feb 23, 2021 10:08 pm
Cleaning out the basement, I found 6 new Autolite #16 spark plugs. These show as being "non-resistor", vs. the correct # 26 resistor plugs. Does anyone know if running these non-resistor plugs will have any adverse effects on the 1975 Mopar electronic ignition components? I'd rather toss them than damage any other components. (I normally run NGK UR4 / 6630.)
PostPosted: Tue Feb 23, 2021 10:15 pm
I have autolite 16 in my 1975 Plymouth duster and works good. The only thing is when i checked the resistance from
tip center electrode to round pin where plug in spark wire was high resistance 50 k ohm. I think there was a
coating on tip so i lightly filed tip till i could get a low resistance reading.
PostPosted: Wed Feb 24, 2021 12:26 am
As long as there's resistance in the wires, you'll be fine.
PostPosted: Thu Feb 25, 2021 10:10 am
OK, thanks for your inputs. P
