| What break in oil is recommended? https://slantsix.org/forum/viewtopic.php?t=65775 |
| Author: | a100gary [ Sat Feb 13, 2021 7:28 pm ] |
| Post subject: | What break in oil is recommended? |
I just finished rebuilding my 225 and want to know what break in oil is recommended? I plan to use 10W30 afterward. Thanks!! Gary |
| Author: | DadTruck [ Sat Feb 13, 2021 7:43 pm ] |
| Post subject: | Re: What break in oil is recommended? |
I use about any conventional 10w30 and a bottle of Comp Engine break in additive and a cheap oil filter. Leave that in for about 50 miles of use. Drain that, re fill with conventional 10w30 another bottle of the Comp break in additive a good filter and run that for 500 or so miles. Change that out and go with a normal service change frequency and the motor oil you plan to use. This is for a vehicle that will see near daily normal use. |
| Author: | a100gary [ Sat Feb 13, 2021 9:21 pm ] |
Thank you. Really appreciate the guidance!! Gary |
