| Torque converter recommendation ? https://slantsix.org/forum/viewtopic.php?t=65877 |
| Author: | Phines1515@yahoo.com [ Sat Mar 27, 2021 4:12 pm ] |
| Post subject: | Torque converter recommendation ? |
I am swapping in a rebuilt 904 into my 64 Signet 200 Convertible. Stock 225 with split exhaust manifolds , Clifford Intake, Holley 390 and HEI. I need recommendations on what to get for a torque converter as far as going with a stock rebuilt one or a higher stall converter and a good place to get one. Thanks in advance ! Pat. |
| Author: | Charrlie_S [ Sun Mar 28, 2021 5:28 am ] |
| Post subject: | Re: Torque converter recommendation ? |
Are you using the PB trans? Is the engine a 67 or earlier, or the 68 up? Makes a difference in the converter. How you use the car, and what you are looking for will make a difference in the converter. |
| Author: | Phines1515@yahoo.com [ Sun Mar 28, 2021 8:43 am ] |
Quote: Are you using the PB trans? Is the engine a 67 or earlier, or the 68 up? Makes a difference in the converter. How you use the car, and what you are looking for will make a difference in the converter.
Original 64 225, Yes staying with push button trans. Just a cruiser. Thank you |
| Author: | Dart270 [ Mon Mar 29, 2021 5:51 am ] |
If you have a little money to spend, call Andre at Edge racing converters and have him build you a 2200-2400 stall for that engine/trans combo. It should be about as efficient as stock and will give you more oomph off the line. Lou |
| Author: | Charrlie_S [ Mon Mar 29, 2021 8:04 am ] |
Quote: If you have a little money to spend, call Andre at Edge racing converters and have him build you a 2200-2400 stall for that engine/trans combo. It should be about as efficient as stock and will give you more oomph off the line.
x2
Lou |
