| Mechanical Advance https://slantsix.org/forum/viewtopic.php?t=65881 |
| Author: | Tireshredder [ Mon Mar 29, 2021 7:46 pm ] |
| Post subject: | Mechanical Advance |
I did an HEI conversion using the dizzy from a ‘79 Aspen SuperSix. Car seems to run noticeably better, but I think I found something odd. There was not appears to be 6-7 degrees of mechanical advance. Is that to be expected? I disassembled and cleaned the spark spinner before it was installed and I didn’t see anything that looked like a binding spot. Possible that I could be on the throttle and the dang thing finds another 10-13 degrees all of a sudden? Base timing is at 16 degrees, total advance takes me to 23-24. If the distributor DOES pick up 10 degrees, am I still in the safe zone? |
| Author: | DusterIdiot [ Mon Mar 29, 2021 8:43 pm ] |
| Post subject: | D |
D |
| Author: | bigslant6fan [ Sun Apr 04, 2021 10:51 am ] |
| Post subject: | Re: Mechanical Advance |
I agree the long-loop heavy spring has to go. My distributor recurve post in the faqs will help. I still have a few spring kits left. |
