| Oil filler tube/dip stick https://slantsix.org/forum/viewtopic.php?t=65898 |
| Author: | crickhollow [ Mon Apr 05, 2021 3:14 am ] |
| Post subject: | Oil filler tube/dip stick |
How can I stop the dip stick from rising from the oil filler tube? When I drive my Valiant the dip stick rises about 1 inch out of the filler tube. |
| Author: | bcschief [ Mon Apr 05, 2021 3:58 am ] |
| Post subject: | Re: Oil filler tube/dip stick |
Excessive blow by most likely time for a rebuild. I would run a compression test and a leak down test. You may also make sure your PCV system is working correctly and you have the correct style oil fill cap. |
