It is currently Sun Nov 15, 2026 2:44 pm
PostPosted: Wed Apr 07, 2021 3:20 pm
Car Model: Lonestar
Did the head ever not have valve stem guides and used just the cast iron hole as a guide? I have a 3614850-5 head. The exhaust valve guides need to be replaced. All valves have some wiggle to them and no longer seal. The exhaust valves themselves look new. Cyl 3 & 4 exhaust valves from what I can tell, have no transition to an installed guide. All other guides have a transition line on both intakes and exhausts. Some guides also are a bit recessed below the cast iron head, others protrude up a bit. Some are flush but you can see the transition. Not 3&4 Exhausts. All exhaust valves are spiraled at the bottom third of the guide.
Just learned from a machinist on YT that the spiral portion on a valve guide needs to be on the spring side, not on the combustion chamber side. So not done correctly in my case I guess.
PostPosted: Wed Apr 07, 2021 5:29 pm
Most likely if it DOES have "installed guides" the head has been thru the machine shop. Original from the factory they just used the head casting itself for the guide. I have 4 /6 heads here. The only one so far that has guides in it is the one I bought fresh from the machine shop. I'm hoping that the head that is currently in the machine shop comes back with them.
I bought the fresh rebuilt head from CL, had been in a guys basement all wrapped in plastic for 30 years by seller's estimate.
Clearly not from same machine shop that my ported head currently sits.
PostPosted: Thu Apr 08, 2021 9:58 am
Car Model: Lonestar
Thanks. It then looks like only some guides on this head were done. AND the 6 exhaust ones that were done, were done with the guides in backwards.
Users browsing this forum: Bing [Bot] and 5 guests
