It is currently Tue Nov 17, 2026 7:26 pm
PostPosted: Mon Apr 05, 2021 3:14 am
How can I stop the dip stick from rising from the oil filler tube?
When I drive my Valiant the dip stick rises about 1 inch out of the filler tube.
PostPosted: Mon Apr 05, 2021 3:58 am
Excessive blow by most likely time for a rebuild. I would run a compression test and a leak down test. You may also make sure your PCV system is working correctly and you have the correct style oil fill cap.
63 Plymouth Valiant Wagon
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
