| Poly urethane control arm bushings https://slantsix.org/forum/viewtopic.php?t=65929 |
| Author: | Rob Simmons [ Sat Apr 17, 2021 3:07 pm ] |
| Post subject: | Poly urethane control arm bushings |
Anyone have experience installing poly control arm bushings? If so, do you have to re-use the old rubber end washers on the new poly bushing? |
| Author: | volaredon [ Sat Apr 17, 2021 6:18 pm ] |
| Post subject: | Re: Poly urethane control arm bushings |
yup. burn out the rubber from the original shells, and the ones I have done have come w/ new sleeves bit any end washers had to be reused. Ive used them on a few vehicles, like them alot, never had a squeak issue, as some say. got em in my 96 Dakota and my 01 Durango, the ones on my 99 Dakota are now looking suspect///am gonna replace those with urethane too. Did my 83 D250 with urethane when I had that rig, too. |
