| Clutch Question https://slantsix.org/forum/viewtopic.php?t=65975 |
| Author: | Greg Ondayko [ Mon May 17, 2021 2:38 pm ] |
| Post subject: | Re: Clutch Question |
Tob could be plastic or garbage.. What brand / vendor is this from? Mods... can this be moved to the tranmission/rearend forum? Greg |
| Author: | Rick Covalt [ Mon May 17, 2021 3:30 pm ] |
Yes it could |
| Author: | Charrlie_S [ Mon May 17, 2021 4:26 pm ] |
Quote: Mods... can this be moved to the tranmission/rearend forum? Greg |
| Author: | DadTruck [ Mon May 17, 2021 5:11 pm ] |
In the 83 D150 I had: a clutch kit from Brute Force that failed in less than two years of service due to the TOB plastic housing de laminating. a clutch kit from NAPA fail in just over two years due to improper staking if the adjustment bolts and the clutch plate levers getting out of adjustment. so yes I would agree that stock replacement 10 inch clutch kits are junk and need to be looked over closely. The most recent clutch kit that I put in, from AMS Automotive-RockAuto has a metal TOB housing and I welded over top of the PP adjustment bolt staking. |
| Author: | volaredon [ Tue May 18, 2021 4:08 am ] |
I t took me 3 clutches about 5000 miles apart to get a good one for my 93 318 Dakota that I converted to a 5 speed from auto. Both times the plastic throw out bearing failed. Perfection brand clutches certainly aren't. The 3rd clutch was. LuK brand and it was great for 72k miles and would have been file for longer if I hadn't totalled it. I'd certainly buy another LuK brand. |
| Author: | d1501983CKP33 [ Tue May 18, 2021 7:03 pm ] |
Thank you, and I'm sorry for posting in the wrong section. It is official, the pressure plate crapped out. I just love doing things twice. |
| Author: | Greg Ondayko [ Wed May 19, 2021 4:19 am ] |
Quote: Quote: Mods... can this be moved to the transmission/rearend forum? Greg Greg |
| Author: | Greg Ondayko [ Wed May 19, 2021 4:22 am ] |
Quote: Thank you, and I'm sorry for posting in the wrong section.
It is official, the pressure plate crapped out. I just love doing things twice. Sorry to hear that. If you can find a local independent clutch rebuilder that could be helpful. also if the disc is in in good shape I would venture getting a new pressure plate - or getting yours rebuilt properly.. I sent a 9" skookum Disc and PP assembly to Falcon Clutch in NY. I called and spoke to the tech on the phone and told them exactly what I wanted on my rebuild with spring pressures facing materials etc and I think I got the part back in something like 3 weeks. They also migh be able to just build one for you. Greg |
| Author: | Charrlie_S [ Wed May 19, 2021 4:50 am ] |
I bought a "Perfection" clutch about a year ago. Haven't installed it yet. All the other brands I bought had a smaller disc, then the pressure plate. That was the reason I chose the Perfection brand. It did come with a plastic TO bearing, When I called Perfection, and complained, and related instances of failures, they sent me a metal TO bearing no charge. |
| Author: | DadTruck [ Wed May 19, 2021 7:11 am ] |
The AMS clutch kit that I installed recently had the correct 10 inch disk. |
| Author: | d1501983CKP33 [ Tue Jun 22, 2021 2:19 pm ] | ||
| Post subject: | Re: Clutch Question | ||
This was the issue.
| Author: | Greg Ondayko [ Wed Jun 23, 2021 11:19 am ] |
I had a similar problem.. Those can be fixed! https://www.slantsix.org/forum/viewtopi ... A+body+bar Greg |
| Author: | d1501983CKP33 [ Wed Jun 23, 2021 5:10 pm ] | ||
Brewer's Performance, Inc 10510State Route 571 Laura, OH 45337-8799 http://www.brewersperformance.com They're nice people over there, had everything I needed. New torque lever with bushings. And I found them by sending an email to a guy on eBay selling a peddle assembly. Ya just never know.
| Author: | volaredon [ Wed Jun 23, 2021 7:32 pm ] |
I've cut the arms off and rewelded them to a "new" hunk of pipe before, to solve that problem. |
