It is currently Fri Nov 20, 2026 12:11 pm
PostPosted: Mon Jun 28, 2021 3:02 pm
Car Model: 1983 B150 (rebuilt 1974 225, 2 bbl)
I rebuilt the BBD on my slant a year or so ago, and tinkered with the "DON'T TOUCH" hex-head adjustment screw on the vacuum cylinder that operates the jet needles. Someone I spoke to along the way said to just turn the screw all the way down clockwise, so I did. It ran okay. But I just swapped in a 'new' engine, so now I'm wondering if that's really the correct baseline setting. I've got a A/F meter on order, so I'm assuming I can get it a lot closer once that's installed. In the meantime, the new/used engine is about to make its first voyage--in this vehicle--to Seattle in record-setting heat in order to tow a boat back to Portland. So, I'm pretty concerned about running too lean. Any advice appreciated.
PostPosted: Mon Jun 28, 2021 10:05 pm
https://www.slantsix.org/forum/viewtopi ... 19&t=35294 Kinda long but deals with your issue
PostPosted: Tue Jun 29, 2021 9:49 am
Thank you kindly for the referral. Looks like just what I was after.
