| 7.25" driveshaft to 8.75" rear end U-joint sizes https://slantsix.org/forum/viewtopic.php?t=66035 |
| Author: | Daddiojoe [ Fri Jun 18, 2021 5:42 pm ] |
| Post subject: | 7.25" driveshaft to 8.75" rear end U-joint sizes |
I did a search and couldn't find this info, so does anybody know what size U-joint I will need when using the old 7.25" driveshaft and a new 8.75" rear? I understand that the size for each axis of the U-joint will be different. Thanks, Joe |
| Author: | Doctor Dodge [ Fri Jun 18, 2021 7:20 pm ] |
| Post subject: | Re: 7.25" driveshaft to 8.75" rear end U-joint sizes |
Chrysler basically used 2 different sized u-joints during the time SL6 engines were in production. The "small" version, with inner "C" clips, found on the 7 1/4 is called a 7260 u-joint. The larger version is the 7290. 8 3/4 axles used both types so you will need to measure to find the size on your replacement 8 3/4. There are special conversion u-joints made to fit small to large or visa-versa but truth is, your 7 1/4 driveshaft will be too long to mate to any 8 3/4 so change the drive shaft yoke to the needed size, when shortening it. DD |
| Author: | Greg Ondayko [ Sat Jun 19, 2021 4:55 am ] |
Here is a handy chart containing info as doc had referenced: https://www.dennysdriveshaft.com/c974_u ... _size.html Greg |
| Author: | Daddiojoe [ Sat Jun 19, 2021 6:30 pm ] |
THANKS GUYS! I lucked out and have the same diameter U-joint on each axis. Doc--you mentioned shortening. That is the next step. Is there a chart out there that shows driveshaft lengths? Never mind--found it with a Google search. Joe |
