| Exhaust headpipe flange thickness? 5/16, or 3/8? https://slantsix.org/forum/viewtopic.php?t=66048 |
| Author: | Jase [ Fri Jun 25, 2021 11:07 am ] |
| Post subject: | Exhaust headpipe flange thickness? 5/16, or 3/8? |
I am building a new exhaust system. It won't be fancy, but I would prefer anvil like durable. How thick should the exhaust headpipe flange be? I am thinking 3/8 is probably overkill, would 5/16ths be the best choice? |
| Author: | volaredon [ Fri Jun 25, 2021 4:46 pm ] |
| Post subject: | Re: Exhaust headpipe flange thickness? 5/16, or 3/8? |
A little overkill won't hurt. 5/16 should be plenty but 3/8 is only another 1/16. Not enough difference to worry about. I'd get the most available. Now if you said 1/4 or 3/8 is definitely go 3/8 |
| Author: | Jase [ Fri Jun 25, 2021 7:13 pm ] |
The exhaust flange I am replacing is thicker than 1/4 but it bends and warps easily. 3/8 it will be, as the local supply house does not have any hot rolled flat in 5/16... |
