It is currently Wed Nov 18, 2026 12:41 pm
PostPosted: Sat Nov 05, 2005 12:12 pm
I need to pull the pan on my 70 dart...
I changed the oil in it three times and each time it looked like tar.... lumpy thick.. just gross! After it runs an hour the oil light comes on...I shut it off for 5 minutes and it runs another hour before the light comes on...It is starving for oil...I need to get the sludge out of the pan...I already took off the vavle cover and hit the rockers and galleys with the parts washer and some Varsol....Cleaned the underside of the Vavle Cover...That made a big difference...
I have already got the car hot started it and dumped a quart of Kerosene in the car and let it run for ten minutes to scrub the inside of the engine...You could not believe the crap that came out of the motor....
I have changed the oil three times now....And it smokes less and runs better all the time...I want to address the oil light coming on after a while...
So... Anyone ever take the pan off while the slant was in the car...Info or advice for me? What is the best way to pull the oil pump
thanks in advance
-Benevolance
PostPosted: Sat Nov 05, 2005 12:18 pm
Before I changed the oil the first time I could only let the car run 5 minutes before the oil light would come on....So I know now that it is starving for oil...
I had thought about just driving it really short distances to the store or gas station and putting 50 miles on it that way....And just keep changing the oil...But I would rather get the crap out of the oil pan I think...
It runs so perfect that I do not want to ruin it by letting the sludge and crap build up in the engine....
The only other thing I would consider doing is maybe a set of Vavle seals...I mean the car did sit for 15 years and smokes just a little...I believe a set of vavle seals would cure it of that. I am hoping that more driving will cure the puff of smoke....It smoked like a diesel when I first got it running...Most of the smoke has gone away
Only 70,000 miles I would like to think there is another 100 k in it before a rebuild.
-Benevolance
PostPosted: Sat Nov 05, 2005 12:19 pm
The oilpump is bolted to the side of the block, with 5, or 6 bolts.
Just unscrew, and pull it straight out.
You may have to jack the engine up , or to the side a bit to get enough room, but it isn´t a big job.
The pan can come out in the car too, I think you need to disconnect the steering thingy under the pan, and jack the engine up a bit...
If it hangs up on the crank, just rotate the crank a bit, so the balance weights get out of the way.
PostPosted: Sat Nov 05, 2005 2:03 pm
I thought about pulling the pump and cleaning it...That maybe this would be a big help to my problems
Just the thought of removing that Dam.ned distibutor again makes me cringe...what a pain in the arse that is...
I will check with the local autozone to see what a rebuilt pump runs...If I am going to remove it...and it is dirt cheap...I might as well replace it.
everything else for the dart has been dirt cheap
Here is a list:
Carb kit.................$12
Rear whl cylinders....10 (2)
Front '' ''................20 (2)
Brake Hoses............10 (2)
Upper rad hose........10
Belts.........................5 (3)
Master Cylinder........15
Three oil changes.......8 (3)
Points Condenser.......5
Have to check the receipts for the Cap and Rotor button...Plugs and wires.... But so far I am well under $200
-Benevolance
PostPosted: Sat Nov 05, 2005 2:12 pm
They are cheap over here, so I don´t see a reason they would cost more over there... :wink:
 Post subject: oil pan
PostPosted: Sat Nov 05, 2005 2:33 pm
if you have access to a engine hoist, pull the engine and do it that way. it won't take more than a couple hours to get the engine out. with the pan gasket being four pieces it will be really hard to get a good seal on all the parts with it in the car. if you have a couple friends to help you it will go that much faster. i did mine in a day by myself.
zedpapa
1970 dodge dart w/225 /6 bored .040" over, holley 390cfm w/vac. sec., compcams 252s, clifford shorty headers w/2.5" exhaust w/flowmaster, f-body 11" front discs, aluminum A-833OD, 8 1/4 w/3.21 SG
soon to have 5 gears!!!
PostPosted: Sat Nov 05, 2005 3:49 pm
While you have the pan off, you might want to change your oil pick-up. Betcha the screen is pretty well clogged up with the same stuff in the pan.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Sat Nov 05, 2005 5:30 pm
If I have to take out the motor I will be ticked off...
I have three mint perfect Slant Six engines...And this one was stuck...A good friend of mine talked me into spending time on the original engine.... I can take out a slant 6 in 1 and a half hours drunk...Done so many of them....Comes from working in a junk yard for years.... I should have thrown the original engine over the bank and just installed a perfect engine I already have...
Matching numbers means about as much to me as pre used toilet paper...
I guess I will just start taking out the engine tonight before bed...Get it jacked up and the torque convertor bolts out...
I wasted 2 days this week messing with the old motor getting fire and unseizing it... Considering that I cannot get anyone to give me $200 for a complete running slant...I was stupid not to just swap the motors out at the start of this project.
Dumb Dumb Dumb
-Benevolance
