| Timing adjustment range https://slantsix.org/forum/viewtopic.php?t=66065 |
| Author: | Bob_A [ Mon Jul 05, 2021 9:21 am ] |
| Post subject: | Timing adjustment range |
Both my timing adjustments (bottom of distributor & plate to block) are fully advanced. Still seems to need a bit more advance though. My question is, can I retard those fully, and advance the gear 1 tooth? And work from there? In other words, does the full range of the adjustments roughly equal 1 tooth on the gear? Thanks! |
| Author: | DusterIdiot [ Mon Jul 05, 2021 7:43 pm ] |
| Post subject: | Re: Timing adjustment range |
Yes, you can re clock the distributor another tooth and reset the slotted bracket. I would check the damper to make sure it's not slipped, and see where #1 TDC sits with your current setting... If the engine is stock and it is a mechanical with vacuum advance distributor, you shouldn't be past 12 BTDC initial... (if it's a running and functional ESC setup then 15 BTDC initial would be fine...) |
