| Proper Door Removal for a 60-62 A Body? https://slantsix.org/forum/viewtopic.php?t=66131 |
| Author: | Greg Ondayko [ Sun Aug 15, 2021 8:36 am ] |
| Post subject: | Proper Door Removal for a 60-62 A Body? |
Do the door Check Rivets have too be chiseled / ground off to properly remove a Toad Body Door? as of right now I cannot perceive any other way to get the door off the car. Greg |
| Author: | emsvitil [ Sun Aug 15, 2021 4:36 pm ] |
| Post subject: | Re: Proper Door Removal for a 60-62 A Body? |
Open Door Back into 1 car garage Should come right off |
| Author: | Rob Simmons [ Mon Aug 16, 2021 5:40 am ] |
I had to remove the rivets. |
| Author: | hyper_pak [ Mon Aug 16, 2021 8:20 am ] |
Yea, rivets out. I found little screw thingies at an office supply store. They are low head, retainer deals for putting paper presentations together. SS. But you have to get the little one to clear the slot. Rob always has good ideas..... |
| Author: | Greg Ondayko [ Tue Aug 17, 2021 11:40 am ] |
Thanks, I was not sure if there was a different way.. It seems all of you 'cept Ed use the same methods. Greg |
