It is currently Sat Oct 10, 2026 5:45 am
PostPosted: Wed Sep 01, 2021 11:26 am
Car Model: 1968 Dodge Dart
Does anyone have information as to the stock length (distance between inlet/outlet) of the built-in automatic transmission cooler for various model years (A-body)? In my '68 Dart, I have a 20+ yr old replacement radiator of unknown make with the straight (not angled) lower coolant outlet design, and it has a 10" cooler. However, I've seen some radiator manufacturers list a 12" cooler, so I didn't know if that was a factory option or not on certain model years or with certain cooling packages.
Thanks
PostPosted: Tue Sep 07, 2021 7:17 am
For those of you with stock A-body radiators, can you measure your distance between the inlet and outlet of the transmission oil cooler (the one that is built into the radiator)? I'm interested in getting dimensions from various model years 68+, to see if they are all 10" or there are differences based on model year or cooling package.
Thanks!
PostPosted: Tue Sep 07, 2021 9:08 am
For what it's worth - '65 Barracuda 10 inches.
--> The Diesel Corvette <--
Users browsing this forum: DuckDuckGo [Bot] and 28 guests
