| 904 questions: As long as it's out, might as well add a few mods? https://slantsix.org/forum/viewtopic.php?t=66175 |
| Author: | MadScientistMatt [ Thu Sep 09, 2021 10:06 am ] |
| Post subject: | 904 questions: As long as it's out, might as well add a few mods? |
So, I had to take the pump out of my 904 transmission since I made the mistake of not getting the torque converter fully seated. I don't intend to do a full rebuild, but as long as the transmission is partway apart, I'm wondering if there are any other basic modifications I should make while it's out. This is a turbo motor in a street/strip application that's more street than strip. So I'm not planning to do a reverse pattern manual valve body or the like. I was thinking of doing a filter change and installing a Trans-Go TF-2 shift kit. Are there any other relatively cheap / easy modifications that I should consider adding at this point? This is a 1966 transmission. |
| Author: | Greg Ondayko [ Thu Sep 09, 2021 10:26 am ] |
| Post subject: | Re: 904 questions: As long as it's out, might as well add a few mods? |
Get an A&A band strut, You can also dicker around with the Lever Ratio - A&A sells higher ratios, and Probably and accumulator blocker - which can be made from a section of AL Tubing..or buy one. Those are easy mods. I would say to get into the clutches as well since its a Turbo car, but That involves a total tear down. Charrlie and others might have other / better ideas but that's what I would start with. Greg |
| Author: | Badvert65 [ Thu Sep 09, 2021 1:28 pm ] |
Put the deep Mopar pan (I think it's a Jeep item) P/N 4007886AB Use the molded rubber gasket P/N 4295875AC |
| Author: | volaredon [ Thu Sep 09, 2021 4:30 pm ] |
Though they didn't have the plastic servos back in 66 I have taken a liking to the billet ones with 2x the seal rings... The apply ones for the bands have 2 where the one hidden behind the valve body has 4.... A&A can get you those. Most tranny's I deal with are 80s and newer, have crappy plastic servos. |
| Author: | MadScientistMatt [ Fri Sep 10, 2021 5:32 am ] |
Thanks, I'll look into these mods. |
