It is currently Sun Oct 11, 2026 6:42 am
 Post subject: Old bulletin float
PostPosted: Sat Apr 06, 2019 12:02 pm
 Post subject: Re: Old bulletin float
PostPosted: Sat Apr 06, 2019 12:05 pm
PostPosted: Sat Apr 06, 2019 12:08 pm
PostPosted: Mon Feb 17, 2020 9:33 pm
This was not just a one time bulletin,these instructions were in the 1977 service manual and every year after that to at least 1983,newest i have to check.
PostPosted: Wed Sep 29, 2021 10:36 am
Car Model: Slant Six M37
This is a wonderful contribution. I would never have dared to do this on vehicle, but I can follow directions and get the work done with half the stress.
Thanks Matv91
PostPosted: Wed Sep 29, 2021 1:01 pm
Also works for Carter BBS. Remove two front/short airhorn-main body screws, remove one long airhorn-main body-throttle body screw and replace with short screw to hold main body to throttle body; repeat with another long screw on the other side of the carb. Remove (applicable linkages and) other two long screws. Proceed with float adjustment.
