It is currently Fri Nov 27, 2026 12:29 am
PostPosted: Mon Nov 01, 2021 8:17 pm
Car Model: Mazda RX8 slant six swap
I'm planning my slant into RX8 swap. The transplant motor has the flat motor mounts, but I notice that there were also a through bolt type. My build will be moderate HP, and my goal is smooth and quiet. Which mounts would be best for those goals? Keep in mind the RX8 has a transmission to rear end brace (not sure what it is called) that prevents the motor from twisting under load.
So not more than stock load on the mounts.
PostPosted: Tue Nov 02, 2021 4:59 am
The flat style would likely be easier to fabricate. The through bolt style would be a little more difficult, but would hold the engine better in event of failure of the rubber part.
PostPosted: Tue Nov 02, 2021 6:04 am
Matt is correct. If it were me and I were fabbing everything anyway, I might find a more common (later model) biscuit-style mount. Even just using the SB Mopar V8 biscuits would be easier, or maybe something used w/a SB Ford or Chev... The top stud of the "new" biscuit would go into your stock mount brackets and for the other end you can fab a mount on the car.
PostPosted: Tue Nov 02, 2021 4:46 pm
The donor motor is from a 1985 Dodgr pickup. Can I use those?
PostPosted: Tue Nov 02, 2021 5:10 pm
The '85 truck mounts should be the "spool type" not the biscuit mounts.
PostPosted: Tue Nov 02, 2021 6:17 pm
No the 85 trucks have flat mounts with the safety interlock in case one of them tears. Actually, I'm not sure if the slant 6 truck ever went to the spool type mount ??
I actually use the 85 truck flat mount in my 65 valiant on the D/S.
 Post subject: D
PostPosted: Tue Nov 02, 2021 7:35 pm
D
PostPosted: Tue Nov 02, 2021 8:05 pm
Is that plenty good for a mild build?
PostPosted: Wed Nov 03, 2021 3:04 am
Sure. I'm running 12's and have not replaced mine. They have been in for 8 years
PostPosted: Wed Nov 03, 2021 5:12 am
I guess I did not realize that the trucks never Changed mounting styles - Sorry about that,
