Adaptronic EMOD013 in a Mazda RX8 slant six swap
https://slantsix.org/forum/viewtopic.php?t=66279
Author:  MazdaRX8/6 [ Fri Nov 05, 2021 8:04 pm ]
Post subject:  Adaptronic EMOD013 in a Mazda RX8 slant six swap
I am swapping a slant into a 2004 Mazda RX8. I would like to keep all of the car's electric functionality. A friend swapped a Toyota 2JZ (inline six, OHC) into his RX8. He suggested this ECU. Any experience or thoughts?
Author:  MazdaRX8/6 [ Mon Nov 08, 2021 10:08 am ]
Post subject:  Re: Adaptronic EMOD013 in a Mazda RX8 slant six swap
I checked with a local RX8/LS swap guy and he told me this unit would run the slant just fine. He's going to help me choose the throttle body and the injectors. I can use the fuel pump lobe (pump is in fuel tank) or use the distributor if I use coil packs.
Author:  Dart270 [ Mon Nov 08, 2021 11:01 am ]
Looks nice. Best of luck with the swap and wiring. I had not heard of that Adaptronic outfit.
Author:  MazdaRX8/6 [ Tue Nov 09, 2021 4:56 am ]
They are in Australia. Big slant fans down under.
Author:  Pierre [ Wed Oct 05, 2022 8:44 pm ]
Looks pricey. Check out the mega squirt.
