| Cam Guru Vocublary Help https://slantsix.org/forum/viewtopic.php?t=66296 |
| Author: | Greg Ondayko [ Tue Nov 16, 2021 4:53 am ] |
| Post subject: | Cam Guru Vocublary Help |
I have been starting to do some David Vizard Research. Can anyone help me understand the difference / similarity in these Cam terms? LCA - Lobe Center line angle - Mr Vizard uses this term in his writing. He describes the Lobe Centerline angle as being Narrow vs wide... Is it the same as.. LSA - Lobe Separation Angle? as I understand that one. Thank you! Greg |
| Author: | Joshie225 [ Tue Nov 16, 2021 6:49 am ] |
| Post subject: | Re: Cam Guru Vocublary Help |
Yes, David Vizard uses LCA when speaking of the angular displacement between the center-lines of the intake and exhaust cam lobes which is the same as LSA. |
| Author: | Greg Ondayko [ Tue Nov 16, 2021 7:40 am ] |
Thanks Joshua - Much appreciated. Greg |
