| Math wizards please step inside https://slantsix.org/forum/viewtopic.php?t=66395 |
Page 1 of 2 |
| Author: | slantzilla [ Wed Jan 05, 2022 9:25 pm ] |
| Post subject: | Math wizards please step inside |
With a 3.500" bore, flat top pistons -.010" down, a gasket compressed .039" and a 56 cc chamber what would I be at for CR? Thanks! |
| Author: | emsvitil [ Wed Jan 05, 2022 11:42 pm ] |
| Post subject: | Re: Math wizards please step inside |
http://www.wallaceracing.com/cr_test2.php |
| Author: | Killer6 [ Thu Jan 06, 2022 12:27 am ] |
Quote: With a 3.500" bore, flat top pistons -.010" down, a gasket compressed .039" and a 56 cc chamber what would I be at for CR?
Actual stroke please....
Thanks! |
| Author: | Rick Covalt [ Thu Jan 06, 2022 3:08 am ] |
If I looked at it right, and using a 3.66" big bore gasket, it came out to 11.1 CR. Please double check my numbers! |
| Author: | hyper_pak [ Thu Jan 06, 2022 6:51 am ] |
One Million To One! |
| Author: | Dart270 [ Thu Jan 06, 2022 7:24 am ] |
I get 11.2:1 with that gasket thickness and assuming stock 4.125" stroke. Lou |
| Author: | slantzilla [ Thu Jan 06, 2022 12:31 pm ] |
Thanks everyone! Yes, stock stroke. |
| Author: | Killer6 [ Thu Jan 06, 2022 3:59 pm ] |
I get 11.2:1 w/a 3.55" gasket bore. Edited; fat fingered gasket thickness. |
| Author: | Killer6 [ Thu Jan 06, 2022 4:23 pm ] |
Quote: One Million To One!
| Author: | Doctor Dodge [ Thu Jan 06, 2022 7:19 pm ] |
I also came up with 11.2 to 1 CR Get a big cam with the intake valve closing around 75* ABDC and you get 8.17 effective compression. DD |
| Author: | GregCon [ Thu Jan 06, 2022 7:32 pm ] |
It won't make a huge difference, but you really need the compressed volume of the gasket. Most of the better gaskets have that printed on the packaging. |
| Author: | Dart270 [ Fri Jan 07, 2022 5:17 am ] |
I always measure my compressed thickness with head torqued on motor with feeler gauges. Felpro is 0.034, ACL is 0.046, Permaseal is 0.047. These are all pretty close to +/-0.001" measurement error and I have seen variations of +/-0.002". Lou |
| Author: | Greg Ondayko [ Fri Jan 07, 2022 7:00 am ] |
Quote: It won't make a huge difference, but you really need the compressed volume of the gasket. Most of the better gaskets have that printed on the packaging.
I doubt many if any of the gasket suppliers for the Slant 6 engine (except for maybe the MLS Group buy) have the compressed thickness advertised... Greg |
| Author: | Killer6 [ Fri Jan 07, 2022 9:00 am ] |
Quote: I always measure my compressed thickness with head torqued on motor with feeler gauges. Felpro is 0.034, ACL is 0.046, Permaseal is 0.047. These are all pretty close to +/-0.001" measurement error and I have seen variations of +/-0.002".
Lou If You're actually cc'ing everything, that's the best way to get as close to perfect as possible. Using dimensional calc. methods, the uninstalled-previously compressed dim. offsets to some extent the volume unaccounted for in the upper piston to bore gap above the ring. |
| Author: | kesteb [ Fri Jan 07, 2022 2:44 pm ] |
Interesting video from the "Riding with Alex Taylor" youtube channel that raising the compression may not be a all that desirable. As it limits the "tuning window". Especially if using power enhancers. https://www.youtube.com/watch?v=jGHxF_5xvJE But then they are playing in a difference league then we are. |
| Page 1 of 2 | All times are UTC-07:00 |
