It is currently Fri Nov 27, 2026 3:46 am
PostPosted: Thu Jan 20, 2022 11:00 pm
Hello again all! My throttle cable snapped at the pedal for my 1966 Plymouth Belvedere II 4 door with the 225 slant. Before I start digging into it, does anyone know a size/part#/or location to buy just the factory replacement or equivalent. Not really looking to do any serious modifications with a universal cable unless I am forced to.
Thanks again....
PostPosted: Fri Jan 21, 2022 4:43 am
Online
I would look into a cable from a '72-'78 Dodge d or w series truck. I am not sure if they are available aftermarket new or not. For sure used on ebay and in the Junkyards/Swap meets etc.
Measure the length of yours and see if the truck cables are the same or similar length.. I bet they can be modified to work.
Plenty on somewhat universal options as well out there from Lokar.
PostPosted: Fri Jan 21, 2022 5:47 am
Car Model: 1966 Dodge Dart
If the housing is OK and it's just the inner cable that's broken, check with your local bicycle shop to see if they can make a replacement.
Matt Cramer
PostPosted: Fri Jan 21, 2022 6:06 am
Online
Ooh.. good call Matt!
PostPosted: Fri Jan 21, 2022 5:59 pm
Pioneer Industries makes many cables so see if they have something that is close.
https://pioneerautoinc.com/all?cat=12
Look at CA-8417 & CA-8418
Users browsing this forum: Ahrefs [Bot] and 1 guest
