It is currently Fri Nov 20, 2026 12:15 am
PostPosted: Wed Apr 27, 2022 4:29 am
Hello All,
I am looking for the Outer Diameter size of the fuel Filler tube(From the quarter Panel to the Gas Tank) for a '64 A Body.
It should be the same as '62-'66's and possibly others.
PostPosted: Thu Apr 28, 2022 8:52 am
I do not know the diameter of the 64 filler tube. I do know the 63 dart had a smaller diameter tube than the 64.
The 63 dart and the 61 valiant filler tubes were the same diameter which was smaller than 64 and later.
PostPosted: Thu Apr 28, 2022 4:41 pm
What's on your Dart? :D
PostPosted: Fri Apr 29, 2022 4:44 am
Mine is Cut off about an inch behind the cap, but I can measure it for you this evening.
PostPosted: Tue May 03, 2022 7:54 am
I got it thanks,
Was trying to get some information quickly as I was ordering parts.
