| Help with hard start when it's hot out. https://slantsix.org/forum/viewtopic.php?t=66484 |
Page 1 of 5 |
| Author: | Slantsix83 [ Thu Feb 24, 2022 12:41 pm ] |
| Post subject: | Help with hard start when it's hot out. |
I currently have a 83 d150 slant six 1bbl and I'm having an issue with hard start when it's warm sunny out. When it starts to cool down or overnight it starts right up. Ill drive it around and stop it and still starts right up. But when i let it sit for about 4 hours in the sun it hard to start after several tries whats going on. |
| Author: | Jase [ Fri Feb 25, 2022 9:50 am ] |
| Post subject: | Re: Help with hard start when it's hot out. |
Hard to start as in the engine turns over slowly and does not catch, Or lots and lots of cranking to get it to start? |
| Author: | SlantSixDan [ Fri Feb 25, 2022 9:50 am ] |
Fuel line mod |
| Author: | Slantsix83 [ Sat Feb 26, 2022 7:06 am ] |
Quote: Hard to start as in the engine turns over slowly and does not catch, Or lots and lots of cranking to get it to start?
Lots of cranking to get it started
| Author: | Slantsix83 [ Sat Feb 26, 2022 7:10 am ] |
Thank you. I will replace and see what happens. Is this a comman issue with the d150s?
| Author: | Greg Ondayko [ Sat Feb 26, 2022 7:44 am ] |
It's Probably common with any Slant 6 in OE configuration with the stock Fuel Line and Modern Fuels. Greg |
| Author: | Slantsix83 [ Sun Feb 27, 2022 4:16 pm ] |
Quote: It's Probably common with any Slant 6 in OE configuration with the stock Fuel Line and Modern Fuels.
Question so with the fuel filter with the 3rd nipple where would I connect the return hose to? Is it somewhere in the sending unit?
Greg |
| Author: | Slantsix83 [ Mon Mar 07, 2022 7:58 pm ] |
I haven't had a chance to fix it but there is also some other issues when the engine is hot and I'm driving it will randomly shut off.and I have to keep on cranking it for it to start. Will the fuel line mod fix this issue or could it be something else.
Greg |
| Author: | Rick Covalt [ Tue Mar 08, 2022 3:08 am ] |
Does it still have the Lean Burn ignition system on it? |
| Author: | Slantsix83 [ Tue Mar 08, 2022 3:38 am ] |
Quote: Does it still have the Lean Burn ignition system on it?
I have no clue. Where is it located at? What does it look like?
| Author: | 69a100 [ Tue Mar 08, 2022 6:24 am ] |
I did that to mine and it didn't do diddly squat to make it any better! YMMV. Good Luck
| Author: | Slantsix83 [ Tue Mar 08, 2022 10:01 am ] |
Quote: Quote:
I did that to mine and it didn't do diddly squat to make it any better! YMMV. Good Luck |
| Author: | 69a100 [ Wed Mar 09, 2022 6:25 am ] |
| Author: | Slantsix83 [ Wed Mar 09, 2022 10:14 am ] |
Quote: Quote: Quote: I did that to mine and it didn't do diddly squat to make it any better! YMMV. Good Luck |
| Author: | SlantSixDan [ Wed Mar 09, 2022 7:03 pm ] |
Quote: So if it's modern gas
It's not; that's the kind of sour-grapes excuse sometimes used by those who won't admit the limits of their knowledge and ability.Quote: isn't their some sort of aftermarket pump? As well as replacing all the hoses to more modern?
It's good practice to go through and replace all your flexible fuel hose with fuel injection hose marked 30R9. The problem isn't being caused by your fuel pump not being the right type (or being incompatible with modern gasoline, etc). Other things to check: make sure your manifold heat control valve isn't stuck in the heat-on position, and make sure your carburetor is in tip-top condition with a correctly-adjusted float (that hasn't absorbed gasoline and gone heavy) and the correct thick, insulating base gasket. Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download, and tune-up parts and technique suggestions in this post. A further modification to reduce the tendency of engine heat after shutdown turning the carburetor into a boiling teakettle is to make a heat shield. There was a factory item, but it has been unavailable for many years, so this would be a make-it-yourself item. Diagram is in this thread. |
| Page 1 of 5 | All times are UTC-07:00 |
