| Levelling a slant https://slantsix.org/forum/viewtopic.php?t=66509 |
| Author: | justa170 [ Sat Mar 19, 2022 10:26 am ] |
| Post subject: | Levelling a slant |
Halp! What part(s) of a slant sit level with respect to the ground (apart from the bottom of the oil pan, which is tricky to stick an angle finder to)? I am currently trying to set the 3-degree slant correctly on a T-bucket installation. |
| Author: | Charrlie_S [ Sat Mar 19, 2022 11:09 am ] |
| Post subject: | Re: Levelling a slant |
Quote: Halp! What part(s) of a slant sit level with respect to the ground (apart from the bottom of the oil pan, which is tricky to stick an angle finder to)? I am currently trying to set the 3-degree slant correctly on a T-bucket installation.
Carb mounting pad on the intake manifold.
| Author: | justa170 [ Sat Mar 19, 2022 4:07 pm ] |
Quote: Quote: Halp! What part(s) of a slant sit level with respect to the ground (apart from the bottom of the oil pan, which is tricky to stick an angle finder to)? I am currently trying to set the 3-degree slant correctly on a T-bucket installation.
Carb mounting pad on the intake manifold. |
