It is currently Sun Oct 11, 2026 11:02 pm
 Post subject: It's happened again....
PostPosted: Tue Mar 29, 2022 9:09 am
I thought I could go awhile without having a slanted vehicle; evidently not too long. Picked up this 1984 D100 Short-bed Custom with 833OD and 2WD. Engine appears to be a late 70s unit and the Lean-Burn has been *ahem* "deleted" be a previous owner. I've already installed an HEI conversion, a nice Carter BBS (to replace the 1945), adjusted valves and all that good stuff. It now runs very well, though I suspect the advance springs in the distributor are too heavy so it's a turd at RPM.
I've taken a few photos just for reference, and will be uploading more as time goes on. You can find themhere.
Future plans are to get a better torque-producing cam ground and installed, installing my custom intake/header assembly purchased from Andrew over a year ago. It will then get a 390 Holley 4bbl and dual 2" header pipes. Additional plans are to rid the truck of all the wiring for the lean-burn system and other items no longer needed. Other than that, it will be used as my daily driver and it may make a few trips down the track too, we shall see.
Anyways, good to be back (again)!
~THOR~
PostPosted: Wed Mar 30, 2022 3:47 pm
Some people never learn...
PostPosted: Sat Apr 02, 2022 8:02 pm
Car Model: 66 Valiant, 82 D150, 94 Ram 2500 TCD, 69 Dart
Sweet deal! Sounds just about like the twin to my 82 D150.
PostPosted: Sun Apr 03, 2022 4:30 am
Welcome Back THOR,
Even when you sell off your slanted vehicles you don't have to leave :D :D
Have fun with your next project!
PostPosted: Sun Apr 03, 2022 5:29 am
Slants happen! Welcome back...
PostPosted: Mon Apr 04, 2022 11:21 pm
Enjoy the new project!
