It's happened again....
https://slantsix.org/forum/viewtopic.php?t=66522
Page 1 of 1
Author:  THOR [ Tue Mar 29, 2022 9:09 am ]
Post subject:  It's happened again....
I thought I could go awhile without having a slanted vehicle; evidently not too long. Picked up this 1984 D100 Short-bed Custom with 833OD and 2WD. Engine appears to be a late 70s unit and the Lean-Burn has been *ahem* "deleted" be a previous owner. I've already installed an HEI conversion, a nice Carter BBS (to replace the 1945), adjusted valves and all that good stuff. It now runs very well, though I suspect the advance springs in the distributor are too heavy so it's a turd at RPM.
I've taken a few photos just for reference, and will be uploading more as time goes on. You can find themhere.
Future plans are to get a better torque-producing cam ground and installed, installing my custom intake/header assembly purchased from Andrew over a year ago. It will then get a 390 Holley 4bbl and dual 2" header pipes. Additional plans are to rid the truck of all the wiring for the lean-burn system and other items no longer needed. Other than that, it will be used as my daily driver and it may make a few trips down the track too, we shall see.
Anyways, good to be back (again)!
~THOR~
Author:  kesteb [ Wed Mar 30, 2022 3:47 pm ]
Post subject:  Re: It's happened again....
Some people never learn...
Author:  halfafish [ Sat Apr 02, 2022 8:02 pm ]
Sweet deal! Sounds just about like the twin to my 82 D150.
Author:  Greg Ondayko [ Sun Apr 03, 2022 4:30 am ]
Welcome Back THOR,
Even when you sell off your slanted vehicles you don't have to leave :D :D
Have fun with your next project!
Author:  Dart270 [ Sun Apr 03, 2022 5:29 am ]
Slants happen! Welcome back...
Author:  SeanDG [ Mon Apr 04, 2022 11:21 pm ]
Enjoy the new project!
