valve cover with ribs
https://slantsix.org/forum/viewtopic.php?t=66592
Page 1 of 1
Author:  Thebearded1 [ Tue May 17, 2022 2:40 pm ]
Post subject:  valve cover with ribs
What year slant sixes came with valve cover that had the 4 ribs between the pvc and oil fill tube?
Interested in one if anyone has one they don't want.
Thanks
Gene
Author:  Greg Ondayko [ Tue May 17, 2022 6:04 pm ]
Post subject:  Re: valve cover with ribs
Thanks
Gene
I think '61-'69 possibly '60 but not sure.
Rob has one on a parts car to be scrapped tomorrow..
viewtopic.php?f=8&t=66591
Author:  Thebearded1 [ Wed May 18, 2022 5:45 pm ]
Thanks Greg! Just saw he posted pictures didn't realize he had that valve cover thanks for the heads up!
Gene
Author:  SlantSixDan [ Wed May 18, 2022 8:21 pm ]
Ribbed covers were used on the '60-'69 model engines.
The very-very-very earliest covers, made in 1959 in the first couple months of the 1960 model year, have a different bolt pattern (head's different too). Odds are against ever seeing one of these.
The rest of the '60 covers are taller at the back end than the '61-up covers—a change made so the 225 would (barely) clear the firewall-mounted heater box on a '61-'62 Lancer-Valiant.
The '60-'65 covers have the front oil cap chimney, plus a shorter rear chimney where the road-draft tube or PCV valve cup attaches. '66-'69 covers have the front oil cap chimney and instead of the rear chimney there's a 1" diameter hole that accepts a rubber grommet which holds the PCV valve.
Unless you have a reason to insist on 100 per cent originality in a pre-'66 engine, the '66-'69 cover's PCV arrangement is a whole lot easier to deal with and less messy. Its heater hose bracket mount is much sturdier, too.
Author:  Thebearded1 [ Wed May 18, 2022 8:29 pm ]
Thanks for the details Dan! No need for originality here so I will look for a 66-69. I just like the ribs more than the plain stamped one i currently have.
Gene
