It is currently Sun Jun 21, 2026 7:08 pm
PostPosted: Wed Jan 26, 2022 5:53 pm
Just reposting Dan's reply about this info here so It does not vanish when the wanted ads get cleaned up.
Standard № TL100 or BWD TLK6 should go right in for you. It's officially a '66-'72 item (the key profile changed) as opposed to the '59-'65 item, but I am about 97 per cent sure I'm recalling correctly that the '66-up lock dropped in on my '64 years ago, and since the '64 took the same lock as the '62…!
Thanks! Greg
