Vacuum operated gasoline evap vapor purge valve
https://slantsix.org/forum/viewtopic.php?t=66674
Page 1 of 1
Author:  Greg Ondayko [ Wed Jul 13, 2022 4:04 pm ]
Post subject:  Vacuum operated gasoline evap vapor purge valve
Hello all,
I am sorting a few things on my 79 volare.. converted to MPEFI with megasquirt in 2008..
I have a new charcoal canister to install, and since there is no longer a carb to operate evap venting properly I need to get a valve for this function.
I bought an electrically actuated valve simulate to what is on my '96 4.0 Litre Jeep.
I don't know if ms2 has the outputs to trigger the valve to the off / closed position during idle.
Would this vacuum valve work with just a vacuum connection to open / actuate off idle?
https://www.amazon.com/ACDelco-214-2294 ... 4381705051
Thanks, Greg
