tranny kicking out of R into N
https://slantsix.org/forum/viewtopic.php?t=66709
Author:  '67 Dart 270 [ Wed Aug 03, 2022 9:39 am ]
Post subject:  tranny kicking out of R into N
I have an A904 automatic slant six, column shift, 1967 dart. Recently, when I'm in reverse it'll kick out of R and into N. It seems to be when I turn the steering wheel while backing up. Is this something in the steering column or perhaps the shift linkage at the tranny?
I'll figure it out, but I was just wondering what first impressions are here, if anyone has seen this - usually your guys' intuition and experience is spot on and saves us time!
Brian
Author:  Greg Ondayko [ Wed Aug 03, 2022 2:06 pm ]
Post subject:  Re: tranny kicking out of R into N
I would assume its the column to transmission adjustment.
Its easy to adjust and fix. Perhaps the service manual has the procedure.
Author:  slantzilla [ Wed Aug 03, 2022 5:01 pm ]
Possibly broken motor/transmission mount.
Author:  Greg Ondayko [ Wed Aug 03, 2022 5:30 pm ]
Good call. Could be one of those too!
Author:  '67 Dart 270 [ Sun Aug 07, 2022 8:40 am ]
Thanks guys, its not a broken mount, so OK the obvious is most likely, I'll check it out, thank you.
