Engine block coolant drain plug tightening reference?
https://slantsix.org/forum/viewtopic.php?t=66711
Page 1 of 1
Author:  Sonic Purity [ Fri Aug 05, 2022 6:47 pm ]
Post subject:  Engine block coolant drain plug tightening reference?
To my amazement, i cannot find a tightening spec in the factory service manual for the engine’s coolant block drain plug. Looked under both Engine and Cooling System sections. A search here on Sl 6.org brought up nothing.
This is for a 1981 hydraulic lifter 225 Slant 6. Here’s the plug:
I’m measuring 1/2" O.D. Head mates with a 9/16" socket. Didn’t have small enough pipe fittings to try and fit, but it looks like it might match a 1/4" I.D. NPT pipe.
Apparently last time it was out i just winged it when i put it back.
Anyone know the proper torque?
Author:  Badvert65 [ Fri Aug 05, 2022 7:03 pm ]
Post subject:  Re: Engine block coolant drain plug tightening reference?
I thought that those were pipe thread. If it is, I don't think there is a torque value for it.
Author:  volaredon [ Sat Aug 06, 2022 5:47 am ]
I've had lots of those out, never torqued one w/a torque wrench yet.
And yeah they're pipe thread
I put petcocks in that hole like what's on the bottom of the radiator
