| my future \6 goals https://slantsix.org/forum/viewtopic.php?t=6676 |
| Author: | moturbopar [ Sat Aug 23, 2003 9:50 pm ] |
| Post subject: | my future \6 goals |
Hi, guy, I am new here but am looking at building a turbo slant. I have been building ford 2.3 turbos (best so far made 273rwhp and 340ftlbs Anyways anyone know how much a set of reworked \6 rods can handle? |
| Author: | shiftless [ Sun Aug 24, 2003 7:18 am ] |
With a set of good forged slugs and good rods, there's no telling how much power we can get out of this thing before it dies. My main concern is the crank, which I've heard stories of people breaking (and this is a *forged* crank). Then again, the stock 2.3 cast crank will support 600HP, go figure. If you go EFI, you can do it pretty cheap if you have the know-how. I'm gonna go MegaSquirt and use a bunch of parts off my 89 Cavalier Z24 parts car. Tip: You can make cheap, effective fuel injector bungs from brass compression fittings. See the articles on the MegaSquirt yahoo forum for pictures. If you go carb, I think you couldn't go wrong with the HyperPak and a small Demon carb. MM&FF just made over 1000HP on a 302 using a blown-thru Demon and had only good things to say about how easy it was to tune. With Wideband O2 it would be effortless. |
| Author: | Dart270 [ Mon Aug 25, 2003 7:17 am ] |
350 RWHP will be doable with stock rods, and a few people have done it with turbo or nitrous. With boost and not a lot of RPM (<6000), you can probably go higher HP with stock rods, but this is uncharted territory at this point. Lou |
